BambuLab P1S
Members must complete the BambuLab P1S: Techniques Class before using this tool
Asmbly has five Bambulab P1S 3D Printers and several Automatic Material System (AMS). Located along the west wall of the Multi-Purpose Room. The P1Ses is named Athena, Zephyrus, Bastet, Hanuman, and Chantico.
Booking Policies
- Don’t let time go to waste. There is a two hour grace period at the beginning of a booking. If the booker is not present after two hours and the printer is still idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[2]] to let us know that this happened. There is a 30 minute grace period after the completion of a print. If the booker is not present and the printer is idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[3]] to let us know that this happened.
Emergency Stop
Control Panel
To see the full list of screen controls, please visit [4]
Printing from the SD Card
Follow this guide: [5]
Stopping or Pausing a print
Firmware Upgrade Warning
Filament
If you need help loading or unloading filament from the rear spool holder, please visit [6] or [7], respectively.
Print Bed Sheet
- Check the waste chute after multimaterial prints and dispose of any purged filament
- [8]
- Bambu Slicer
- STLFinder
- Thingiverse
- Printables
- Yeggi
- Buy from makers on Etsy
Places to buy filament:
- Polymaker
- Amazon
- Clean the sheet (wait for it to cool down if it is hot) with Isopropyl Alcohol (in a squeeze bottle with the other tools)
- Wash the sheet with hot water and dish soap at the coffee area sink. Make sure the sheet is completely dry before reinstalling it.
- If printing in ASA or ABS, ensure that the chamber is preheated by heating the bed to 100C for a minimum of 30 minutes prior to starting a print. Consider adding a brim as well.
- If using a textured sheet side, try a smooth sheet side, and vice versa.
- Contact a steward
This often happens due to molten filament not sticking to the print sheet, and causes problems when you restart the print.
- Lower the print bed via the printer screen or Bambu Studio so you can see the underside of the nozzle
- Touch some cool plastic to the still-hot plastic on the nozzle. It should stick and let you pull the mess away
- Use the brass brush in the tool caddy to wipe the heated nozzle clean
Other
If you are unsure what is causing a particular issue, it is always best to contact a steward and fill out a problem report
Regular Maintenance
Follow this guide: P1P Maintenace
Moving the printers
The printer is ONLY to be moved by stewards, or by members who have received explicit permission from a steward.
Unless granted permission by the machine's host, the printer is not to be moved outside of the Multipurpose Room or Textiles Room.
Rebooting Procedure
Z-Height Problems
The P1S will perform automatic Z-Height calibration before every print. It cannot be manually calibrated like on the Prusa MK3S+ printers. If the print appears too close or too far away from the bed, check the following:
- Make sure the printer knows which sheet is on the bed. Different sheets have different calibration heights.
- Make sure the bed is seated properly and not warped.
- Make sure there is no debris on the nozzle tip when automatic calibration is being performed at the start of a print.
Perform Auto Calibration
The P1S auto calibration will check items such as vibration compensation, motor noise cancellation, and auto bed leveling. The calibration takes about 26 minutes.
Navigate to the calibration option using the screen or Bambu Studio: [9]
Filament Sensor Inspection
If the following happens:
- Printer sends the error message "Filament failed to send to the extruder", but there is filament in the tube above the toolhead.
- When using the AMS, printer sends the message "Please pull the filament from the external spool", but there is no filament in the tube above the toolhead.
- The printer sends the message "Please insert the filament into the port until it can no longer be pushed", but the filament has entered the extruder.
Please follow this guide: [10]
Hotend Clumping
In the event of hotend clumping, please follow this guide: [11]
Bed Not Heating
In the event that the bed does not heat up, please follow this guide: [12]
