Laguna Swift Vacuum CNC
Revision as of 17:12, 26 February 2026 by Rolo (talk | contribs)
Members must complete the Intro to CNC Routers Class before using this tool
This should serve as a reference on how to properly finish up your CNC session. Please pay special attention to #6 and #7.
  6. Empty Dust Collector Barrel and Bag (if present)
  7. Clean DC Filter. (Big CNC - Rotate the handle).
Filter Cleaning Steps
These are required after every use and should take no more than 10 seconds.
- Rotate the handle on the filter. - Hear the flaps flapping - See the dust dropping
Grizzly 1.5HP G0944 Dust Collector
