Prusa XL
http://xl-printer.asmbly.org
username: maker
password: BcdhPrsUYS7EFz5
ASMBLY Prusa XL Printers
PrusaXL
Status Active
Video Feed Video Feed
Manufacturer Prusa
Model XL
Nozzle Size 0.4mm
Nozzle Count 5
Filament Size 1.75mm
Max Bed Temperature 120C
Max Nozzle Temperature 290C
Max Print Speed 400mm/s
Extruder Type Direct
Manual [1]
Booking Policies
Template loop detected: Template:Excerpt
Apollo, Hermes, and Sunwukong
All three printers
Print volume is 360mm x 360mm x 360mm (14.1" x 14.1" x 14.1")
Emergency Stop
Control Panel
PrusaLink
Stopping or Pausing a print
Firmware Upgrade Warning
Filament
Print Bed Sheet
Calibrated for Smooth1
Nozzles / Hotend
yo.asmbly.org
Places to buy filament:
  4. Contact a steward
Trouble loading filament
If you are loading filament and it doesn't want to come out of the nozzle, here are some troubleshooting steps.
Make sure you have cut the end of the filament at a 45° angle, use the diagonal cutters if not
Check if your filament is loading into the tube that leads to the nozzle
  1. Lift the catch that holds the idler door
  1. Open the idler door
  1. Look at whether the filament is entering the tube at the bottom of the idler gear
Filament missing tube
Filament entering tube
Other
Regular Maintenance
Moving the printers
Rebooting Procedure
Z Problems
