Prusa MK3S+
Apollo
Status Active
Video Feed Video Feed
Manufacturer Prusa
Model i3 MK3S+ & Pi 3B
Nozzle Size 0.4mm
Nozzle Count 1
Filament Size 1.75mm
Max Bed Temperature 122C
Max Nozzle Temperature 295C
Max Print Speed 100mm/s
Extruder Type Direct
Manual MK3S+ Handbook
Hermes
Status Active
Manufacturer Prusa
Model i3 MK3S+ & Pi 4B
Nozzle Size 0.4mm
Nozzle Count 1
Sunwukong
Status Active
Manufacturer Prusa
Nozzle Size 0.4mm
Nozzle Count 1
Booking Policies
  1. Time booked for 3D printing in Skedda does not count against your weekly Asmbly hours, but time on the XL is limited to 48 hours per week. If you want to print a large object that will take longer, book the first 48 hours and email 3dprinters@asmbly.org to request more time. If it's available, we'll try to book it for you.
  2. It is fine for a print to continue while Asmbly is closed.
  3. You may book up to two 3D printers at a time.
  4. Book all of the time you need. Only print during time that you have booked. Don’t start prints that will go beyond your booked time. If your print has been paused or stopped because of a problem, don’t resume or restart it if it will go beyond your booked time. If time is available after your booked time, feel free to book more time to finish your print. If another member has already booked time that your print would need to use, and you contact them and get their approval, you may finish your print. However, if you do not manage to contact them, or if they do not agree to let you continue, then do not start, resume, or restart prints that would go into their time.
  5. Time you book is yours. If you arrive for your booked time and a print is ongoing, you may stop that print. If a print only has a few minutes remaining, it would be nice if you let it finish, but you are not under an obligation to do so.
  6. Give back time that you don’t need. If you realize you’ll be late, change your booking to start when you’ll actually be ready to start. If your print ends early, end your booking early in Skedda.
  7. Don’t let time go to waste. There is a two hour grace period at the beginning of a booking. If the booker is not present after two hours and the printer is still idle, another member may claim the remainder of the time on a first-come, first-served basis. Email 3dprinters@asmbly.org to let us know that this happened. There is a 30 minute grace period after the completion of a print. If the booker is not present and the printer is idle, another member may claim the remainder of the time on a first-come, first-served basis. Email 3dprinters@asmbly.org to let us know that this happened.
Apollo, Hermes, and Sunwukong
All three printers
Emergency Stop
Control Panel
Octoprint
Because the Octoprint servers are installed individually to each printer, it is safe to reboot a printer and Octoprint without disrupting the other printers in operation. This was not the case with the previous printers.
If you are doing a print that needs to pause, for example to insert magnets, please read Pausing prints in Octoprint
Stopping or Pausing a print
Firmware Upgrade Warning
Filament
Print Bed Sheet
Calibrated for Smooth1
Asmbly stewards will prioritize keeping the Prusa Satin sheets calibrated. You are welcome to use other sheets, but other sheets have different thicknesses, and you are responsible for calibrating the Z for your chosen sheets. To do this:
  1. Remove the Satin sheet from the printer
  2. Put your chosen sheet on the printer
  3. In the menus, select your chosen sheet. Use SMOOTH1 for the Prusa Smooth sheet, TEXTURED1 for the Prusa Textured sheet, and CUSTOM1 for other sheets
  4. Calibrate Z for your sheet
    1. Double check that you have the correct sheet selected. Please don't change the SATIN1 calibration if a different sheet is on the bed
    2. Use the First Layer Calibration tool in the printer's menus to run a quick calibration
    3. OR Calibrate the Z live using the Live Adjust Z menu item. You should find two gcode files on each of the SD cards for the printers named calibration_E and calibration_network which are single-layer prints designed to help you dial in the setting, but you can also do this during the first layer of your own print if first layer quality is not critical.
    4. If you find that you need to calibrate the Z beyond -2.000mm, please file a problem report. This indicates that the Z sensor needs to be adjusted.
To switch back to the Satin sheet:
  1. Remove the other sheet from the printer
  2. Put a Satin sheet on the printer
  3. In the menus, select SATIN1. This setting should be properly calibrated.
  4. If you get bad first layers (see First Layer Calibration to see what that looks like), follow the calibration instructions above or file a Problem Report
You will find various sheets in the top drawer of the black cabinet to the right of the enclosure for the Prusa printers:
Nozzles / Hotend
All three Prusa i3 mk3s+ printers have been upgraded with the E3D Revo hotend (from the stock E3D V6). They are all equipped with the 0.4mm abrasion-resistance ObXidian nozzles. You may use your own nozzles, with the following rules:
  1. You must demonstrate that you know how to change the nozzles to a 3D Printing volunteer
  2. You must book the printer in Skedda until you return it to the original state. You must do a test print to ensure that the first layer is properly calibrated again for the 0.4mm ObXidian nozzle.
yo.asmbly.org
Design for 3D-Printing
Places to buy filament:
  5. Contact a steward
Other
Regular Maintenance
Octoprint
Moving the printers
Rebooting Procedure
Z Problems
Note: z-height adjustments are given with negative numbers, so -1.500 is "lower" than -1.200.
Your print's first layer should be smooth and even. If it's not, the Z probably needs to be fine tuned. Try this:
  2. Run through the Calibration > First Layer Calibration process on the control panel (Section 6.3.9 of the handbook)
    1. Calibration Network
    2. Calibration E
    1. The proper height for the sensor is about 1mm. There may be some zip ties around that can help provide a guide, but be sure to measure them with calipers. Some of the zip ties around are too flat.
