Prusa XL
http://xl-printer.asmbly.org
username: maker
password: BcdhPrsUYS7EFz5
ASMBLY Prusa XL Printers
PrusaXL
Status Active
Video Feed Video Feed
Manufacturer Prusa
Model XL
Nozzle Size 0.4mm
Nozzle Count 5
Filament Size 1.75mm
Max Bed Temperature 120C
Max Nozzle Temperature 290C
Max Print Speed 400mm/s
Extruder Type Direct
Manual [1]
Booking Policies
Section '3D_Printer_Booking_Policies' not found
Apollo, Hermes, and Sunwukong
All three printers
Print volume is 360mm x 360mm x 360mm (14.1" x 14.1" x 14.1")
Emergency Stop
Control Panel
PrusaLink
Stopping or Pausing a print
Firmware Upgrade Warning
Filament
Print Bed Sheet
Calibrated for Smooth1
Nozzles / Hotend
yo.asmbly.org
Places to buy filament:
  4. Contact a steward
Trouble loading filament
If you are loading filament and it doesn't want to come out of the nozzle, here are some troubleshooting steps.
Make sure you have cut the end of the filament at a 45° angle, use the diagonal cutters if not
Check if your filament is loading into the tube that leads to the nozzle
  • Lift the catch that holds the idler door
  • Open the idler door
  • While you have the door open, look for any debris (usually ground up filament bits) on the idler gear. Use the air bulb (in the drawer of the wood table) to clean it out
  • Look at whether the filament is entering the tube at the bottom of the idler gear
Filament missing tube Filament entering tube
  • If the filament is missing the tube, try grabbing the end with a pair of pliers and manually inserting it into the tube. Close the door and the catch and try loading again
  • If the filament is aligned with with the tube, but nothing is coming out of the nozzle, probably some filament is stuck in the tube. Let's melt it out! Start by unloading your filament and then unscrew the end of the bowden tube.
  • Grab a piece of cleaner filament
  • Insert it into the extruder
  • Have the printer load filament at a temperature higher than what's in the tube. You can use a very high setting like PA if you don't know what the last filament was.
  • Hopefully, you should see something oozing out of the nozzle, and then eventually the translucent white of the cleaning filament. Use the "Purge More" command until the color is mostly translucent.
  • Unload the cleaning filament using the console and screw the bowden tube back in. Your filament should now load.
If these steps do not fix your problem, please open a problem report
There are other techniques for clearing problems like this (like using acupuncture needles, pressing the filament through with a tool, doing a cold pull, etc.). If you're comfortable doing those, feel free to try them, but the steps above usually resolve the problems we've seen on the XL.
Other
If you are unsure, feel free to contact a steward or fill out a problem report
Regular Maintenance
Moving the printers
Rebooting Procedure
Z Problems
