Dione
(Redirected from 000257)
Asmbly owns the ELEGOO Saturn 4 Ultra SLA printer.
[[File:|alt=Photo of Elegoo Saturn 4 Ultra Resin printer|center|frameless]]
Dione (Elegoo Saturn 4 Ultra)
Manufacturer Elegoo
Model Elegoo Saturn 4 Ultra
LCD 10-inch 12K Mono LCD
System EL3D-4.0
Slicer Software ChituBox & Autodesk Fusion
Layer Thickness 0.01 - 0.2mm
Z Axis Accuracy 0.02mm
Build Volume 218.88mm(L) * 122.88mm(W) * 220mm(H)
Light Source COB Light Source + Fresnel Collimating Lens (Wavelength 405 nm)
Weight 19.3kg
Power Requirements 100-240V 50/60Hz 24V 6A
Printer Dimensions 327.4mm(L) * 329.2mm(W) * 548mm(H)
Resin Safety
  • Avoid breathing vapors.
The Saturn 4 Ultra is an SLA printer that combines fast print speeds with top-notch quality. It includes a USB-attachable carbon filter to reduce odors and allows file uploads via USB or Wi-Fi for easy connectivity. Its high-resolution output makes it perfect for detailed, precision projects.
Available Resin Materials
You may purchase resin here.
Chitu Box Slicer Setup
  2. Go to "Settings" and select ELEGOO Saturn 4 Ultra as the default printer.
Resin Density: 1.1g/mL
Layer Height: 0.05mm
Number of Bottom Layers: 2
Exposure Time: 2.5s
Leveling the bed
  8. Note from a Steward: Please be aware that at least some versions of CHITUBOX will attempt to auto correct an infrequent issue on build plate leveling by including in the slicing data a command to over shoot the the set zero that can lead to print fails by print over compression. After leveling, run a test print and then manually adjust the z height by the .1mm it is off by the calipers. As of 4/11/2025 the proper z hieght post leveling needs to be set at .9 mm above level sheet.
Post-Processing
If your print fails, particularly if some parts of the print don't adhere to the bed, it's likely you'll need to do a Resin Tank Cleanup. Please try to leave the tank debris-free for the next user.
3D Printers Space Team
Common Projects
